[postgis-devel] Issue 148 in postgis: st_touches doesn't work as it	should on st_touches(line,point)
    codesite-noreply at google.com
    Wed Apr  8 08:37:38 PDT 2009
Updates:
	Status: Invalid
Comment #1 on issue 148 by robe.... at cityofboston.gov: st_touches doesn't
http://code.google.com/p/postgis/issues/detail?id=148
Nicklas -- I think this is by design.  Touches is a weird thing -- but in
the docs it
says
2 geometries only touch if their boundaries share points together.  The
boundary of a
line string is a MULTIPOINT.  If you do this
SELECt ST_AsText(ST_Boundary('LINESTRING(0 0, 1 1, 0 2)'::geometry))
you get this -- MULTIPOINT(0 0,0 2)  -- so the only geometries that qualify
as
touching this linestring are 0 0  and 0 2 as you have observed.
Kevin please correct me if I am wrong because this is a very touchy subject
(well in
terms of nuances anyway)
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
