[postgis-devel] Issue 148 in postgis: st_touches doesn't work as it should on st_touches(line,point)
codesite-noreply at google.com codesite-noreply at google.com
Wed Apr 8 08:57:49 PDT 2009
Comment #2 on issue 148 by ke... at refractions.net: st_touches doesn't work
http://code.google.com/p/postgis/issues/detail?id=148
Regina, you are correct.
Another way to state the relation is:
Geometry (a) touches geometry (b) if and only if:
1. the intersection of (a) and (b) is not the empty set (which means they
have to
interact somehow) AND
2. the intersection of the interior of (a) and the interior of (b) is not
the empty set.
This means that intersection must occur on the boundary of at least one of
the
geometries.  Since, according to the specs, a point does not have a
boundary (only an
interior), if follows that ST_Touches returns true only if the point lies
on the
boundary (or endpoints) of the line.
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
