[postgis-devel] Issue 147 in postgis: regress_ogc_prep fails with PostgreSQL crash
codesite-noreply at google.com
Wed Apr 8 05:56:26 PDT 2009
Comment #5 on issue 147 by Sandro.Santilli: regress_ogc_prep fails with
PostgreSQL crash
http://code.google.com/p/postgis/issues/detail?id=147
PreparedPolygonContainsProperly was calling a method on an object right
after
deleting it. Should be fixed as of revision 2323.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
