[postgis-devel] Issue 147 in postgis: regress_ogc_prep fails with PostgreSQL crash
codesite-noreply at google.com
Wed Apr 8 07:09:49 PDT 2009
Comment #6 on issue 147 by mloskot: regress_ogc_prep fails with PostgreSQL
crash
http://code.google.com/p/postgis/issues/detail?id=147
I confirm the bug has been fixed on both architectures, Intel 32-bit and
64-bit:
mloskot at vb-ubuntu810-i386:~/dev/postgis/_svn/trunk$ svn info | grep Revision
Revision: 3986
mloskot at vb-ubuntu810-x64:~/dev/postgis/_svn/trunk$ svn info | grep Revision
Revision: 3986
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
