[postgis-devel] Probe_Geometry_Columns() only in public schema?
Kevin Neufeld kneufeld at refractions.net
Tue Apr 21 08:38:10 PDT 2009
You could try to import the new Populate_Geometry_Columns() that's available in 1.4 into your 1.3.3 database.  One
variant of this method takes a table oid which you could use to iterate over all tables in a particular schema.
http://postgis.refractions.net/documentation/manual-svn/Populate_Geometry_Columns.html
The difference between Probe_Geo.. and Populate_Geo... is that probe requires that your geometry columns were originally
added to your tables via AddGeometryColumns() (or the table constraints were added manually), populate does not.
-- Kevin
Per-Olof Norén wrote:
> Hi guys,
> I have a database where all tables with geometry data is in (8)
> different schemas.
> Having destroyed the data in my geometry_columns table, I looked around
> for managment function and found Probe_Geometry_Columns().
> After running probe_geometry_columns it reports having scanned only my
> two tables in the public schema (geometry_columns + spatial_ref_sys)
> Is this a known limitation on 1.3.3 ?
> (select postgis_lib_version() => 1.3.3)
> A suggestion might be to supply a schema name as argument?
> Regards,
> Per-Olof
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
