[postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
Paragon Corporation
lr at pcorp.us
Tue Apr 21 18:36:36 PDT 2009
Okay just tried on my OpenSUSE 11 box. Make check fails on kml check. It
looks like a rounding error. I assume that is okay.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paragon
Corporation
Sent: Tuesday, April 21, 2009 7:43 PM
To: 'PostGIS Development Discussion'
Subject: RE: [postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
Paul,
Thanks for doing this.
I'll give it a try probably sometime tomorrow or later tonight if I'm up to
it.
Thanks,
Regina
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Tuesday, April 21, 2009 4:11 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
I've wrapped an 'rc1' and placed it here:
http://postgis.refractions.net/download/postgis-1.3.6rc1.tar.gz
Please test it a bit and then we'll announce to the wider audience.
P
On Mon, Apr 20, 2009 at 7:14 PM, Paragon Corporation <lr at pcorp.us> wrote:
> I've been testing under Windows 2003 and seems okay - comparing some
> stress tests between 1.3.5 and 1.3.6 (though was using GEOS 3.1.0 --
> still need to test with 3.0.3.
> My tests on 8.4 beta 1 under windows I think I'm seeing some
> discrepancies between ST_Within behavior, but could be my diffing is
> out of wack and haven't determined if its an issue with 1.3.6 or
> 1.4.0. I had installed both under the same 8.4 beta 1 install in
> separate more or less identical databases. Still yet to test on Linux.
> It would really help if we have an up to date tar ball for both at the
> very least.
> The Union behavior between the 1.3.6 and 1.4.0 is very different, but
> I think that is expected and under an OpenJump microscope the results
> at least have the same number of points and look visually the same.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090421/90fa1d2a/attachment.obj>
