[postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Apr 21 23:52:53 PDT 2009
Paragon Corporation wrote:
> Okay just tried on my OpenSUSE 11 box. Make check fails on kml check. It
> looks like a rounding error. I assume that is okay.
Not really. If 1.3.5 passes all tests on the same box then it should be
considered a regression. It's probably worth giving Olivier a poke, as
we spent some time at the code sprint adding precision specifiers to the
regression tests to remove this problem. I can't remember whether the
changes were done for the 1.3 branch as well as trunk though.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
