[postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
Olivier Courtin
olivier.courtin at camptocamp.com
Fri Apr 24 02:10:53 PDT 2009
Mark,
>> Okay just tried on my OpenSUSE 11 box. Make check fails on kml check. It
>> looks like a rounding error. I assume that is okay.
> Not really. If 1.3.5 passes all tests on the same box then it should be
> considered a regression. It's probably worth giving Olivier a poke, as we
> spent some time at the code sprint adding precision specifiers to the
> regression tests to remove this problem. I can't remember whether the
> changes were done for the 1.3 branch as well as trunk though.
We only change kml decimal places in trunk (and so we did'nt commit anything
related to KML export in Toronto for 1.3 branche)
Cf: <http://trac.osgeo.org/postgis/browser/branches/1.3/regress>
Olivier
