[postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
Kevin Neufeld
kneufeld at refractions.net
Sun Apr 26 08:22:05 PDT 2009
:) correction. These results are for an FC3 box, not centos, but I do
get the same error on my centos5.3 box as well.
Kevin Neufeld wrote:
> It passes regression tests on my centos5.3 box, but there are errors
> in the log files...
> Creating spatial db postgis_reg
> TMPDIR is /tmp/pgis_reg_25038
> PostgreSQL 8.3.7 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.4.4
> 20050721 (Red Hat 3.4.4-2)
> Postgis 1.3.6RC1 - 2009-04-26 07:03:29
> GEOS: 3.1.0-CAPI-1.5.0
> PROJ: Rel. 4.4.9, 29 Oct 2004
> Run tests: 40
> Failed: 0
> [kneufeld at turtle regress]$ grep ERROR /tmp/pgis_reg_25038/*
> /tmp/pgis_reg_25038/dumper.err:Initializing... ERROR: Cannot determine
> spatial reference (empty table or unknown spatial ref).
> /tmp/pgis_reg_25038/regress_log:ERROR: table "loadedshp" does not exist
> -- Kevin
> Paul Ramsey wrote:
>> I've wrapped an 'rc1' and placed it here:
>> http://postgis.refractions.net/download/postgis-1.3.6rc1.tar.gz
>> Please test it a bit and then we'll announce to the wider audience.
>> P
>> On Mon, Apr 20, 2009 at 7:14 PM, Paragon Corporation <lr at pcorp.us>
>> wrote:
>>> I've been testing under Windows 2003 and seems okay - comparing some
>>> stress
>>> tests between 1.3.5 and 1.3.6 (though was using GEOS 3.1.0 -- still
>>> need to
>>> test with 3.0.3.
>>> My tests on 8.4 beta 1 under windows I think I'm seeing some
>>> discrepancies
>>> between ST_Within behavior, but could be my diffing is out of wack and
>>> haven't determined if its an issue with 1.3.6 or 1.4.0. I had
>>> installed
>>> both under the same 8.4 beta 1 install in separate more or less
>>> identical
>>> databases. Still yet to test on Linux.
>>> It would really help if we have an up to date tar ball for both at
>>> the very
>>> least.
>>> The Union behavior between the 1.3.6 and 1.4.0 is very different, but I
>>> think that is expected and under an OpenJump microscope the results
>>> at least
>>> have the same number of points and look visually the same.
>>> Thanks,
>>> Regina
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
