[postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
Kevin Neufeld
kneufeld at refractions.net
Mon Apr 27 14:19:49 PDT 2009
I agree. I don't think the regression tests actually load spatial_ref_sys at all, so that would make sense that the
loader can't find a corresponding SRID.
-- Kevin
Paul Ramsey wrote:
> Sounds like something from Regina's prj export options...
> P
> On Sun, Apr 26, 2009 at 12:13 AM, Kevin Neufeld
> <kneufeld at refractions.net> wrote:
>> It passes regression tests on my centos5.3 box, but there are errors in the
>> log files...
>> Creating spatial db postgis_reg
>> TMPDIR is /tmp/pgis_reg_25038
>> PostgreSQL 8.3.7 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.4.4
>> 20050721 (Red Hat 3.4.4-2)
>> Postgis 1.3.6RC1 - 2009-04-26 07:03:29
>> GEOS: 3.1.0-CAPI-1.5.0
>> PROJ: Rel. 4.4.9, 29 Oct 2004
>> Run tests: 40
>> Failed: 0
>> [kneufeld at turtle regress]$ grep ERROR /tmp/pgis_reg_25038/*
>> /tmp/pgis_reg_25038/dumper.err:Initializing... ERROR: Cannot determine
>> spatial reference (empty table or unknown spatial ref).
>> /tmp/pgis_reg_25038/regress_log:ERROR: table "loadedshp" does not exist
>> -- Kevin
>> Paul Ramsey wrote:
>>> I've wrapped an 'rc1' and placed it here:
>>> http://postgis.refractions.net/download/postgis-1.3.6rc1.tar.gz
>>> Please test it a bit and then we'll announce to the wider audience.
>>> P
>>> On Mon, Apr 20, 2009 at 7:14 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>>> I've been testing under Windows 2003 and seems okay - comparing some
>>>> stress
>>>> tests between 1.3.5 and 1.3.6 (though was using GEOS 3.1.0 -- still need
>>>> to
>>>> test with 3.0.3.
>>>> My tests on 8.4 beta 1 under windows I think I'm seeing some
>>>> discrepancies
>>>> between ST_Within behavior, but could be my diffing is out of wack and
>>>> haven't determined if its an issue with 1.3.6 or 1.4.0. I had installed
>>>> both under the same 8.4 beta 1 install in separate more or less identical
>>>> databases. Still yet to test on Linux.
>>>> It would really help if we have an up to date tar ball for both at the
>>>> very
>>>> least.
>>>> The Union behavior between the 1.3.6 and 1.4.0 is very different, but I
>>>> think that is expected and under an OpenJump microscope the results at
>>>> least
>>>> have the same number of points and look visually the same.
>>>> Thanks,
>>>> Regina
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
