[postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
Paragon Corporation
lr at pcorp.us
Mon Apr 27 14:33:07 PDT 2009
It won't output a prj if spatial_ref_sys is empty and will throw a warning
but will continue on.
Thank,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
Neufeld
Sent: Monday, April 27, 2009 5:20 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
I agree. I don't think the regression tests actually load spatial_ref_sys
at all, so that would make sense that the loader can't find a corresponding
SRID.
-- Kevin
Paul Ramsey wrote:
> Sounds like something from Regina's prj export options...
> P
> On Sun, Apr 26, 2009 at 12:13 AM, Kevin Neufeld
> <kneufeld at refractions.net> wrote:
>> It passes regression tests on my centos5.3 box, but there are errors
>> in the log files...
>> Creating spatial db postgis_reg
>> TMPDIR is /tmp/pgis_reg_25038
>> PostgreSQL 8.3.7 on i686-pc-linux-gnu, compiled by GCC gcc (GCC)
>> 3.4.4
>> 20050721 (Red Hat 3.4.4-2)
>> Postgis 1.3.6RC1 - 2009-04-26 07:03:29
>> GEOS: 3.1.0-CAPI-1.5.0
>> PROJ: Rel. 4.4.9, 29 Oct 2004
>> Run tests: 40
>> Failed: 0
>> [kneufeld at turtle regress]$ grep ERROR /tmp/pgis_reg_25038/*
>> /tmp/pgis_reg_25038/dumper.err:Initializing... ERROR: Cannot
>> determine spatial reference (empty table or unknown spatial ref).
>> /tmp/pgis_reg_25038/regress_log:ERROR: table "loadedshp" does not
>> exist
>> -- Kevin
>> Paul Ramsey wrote:
>>> I've wrapped an 'rc1' and placed it here:
>>> http://postgis.refractions.net/download/postgis-1.3.6rc1.tar.gz
>>> Please test it a bit and then we'll announce to the wider audience.
>>> P
>>> On Mon, Apr 20, 2009 at 7:14 PM, Paragon Corporation <lr at pcorp.us>
wrote:
>>>> I've been testing under Windows 2003 and seems okay - comparing
>>>> some stress tests between 1.3.5 and 1.3.6 (though was using GEOS
>>>> 3.1.0 -- still need to test with 3.0.3.
>>>> My tests on 8.4 beta 1 under windows I think I'm seeing some
>>>> discrepancies between ST_Within behavior, but could be my diffing
>>>> is out of wack and haven't determined if its an issue with 1.3.6
>>>> or 1.4.0. I had installed both under the same 8.4 beta 1 install
>>>> in separate more or less identical databases. Still yet to test on
>>>> Linux.
>>>> It would really help if we have an up to date tar ball for both at
>>>> the very least.
>>>> The Union behavior between the 1.3.6 and 1.4.0 is very different,
>>>> but I think that is expected and under an OpenJump microscope the
>>>> results at least have the same number of points and look visually
>>>> the same.
>>>> Thanks,
>>>> Regina
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
