[postgis-devel] PostGIS 1.4 and PostgreSQL 8.4
Paragon Corporation
lr at pcorp.us
Wed Aug 5 23:42:57 PDT 2009
Dave,
Both should work fine. The version we compiled was the newest libiconv2,
but we tested the shp2pgsql with the old version and the new and it seemed
to work fine for us in either case and didn't notice any issues with the
PostgreSQL behavior we have.
So I think you are fine sticking with what is packaged with the PostgreSQL
8.4 if its got the same name.
The installation issues discussed before were caused because PostGIS install
tried to overwrite the libiconv-2.dll which was already present in
PostgreSQL installs so the solution has always been to just skip it if you
have it. Although in my PostgreSQL 8.4 install for some reason the file
that I got when installing was libiconv.dll (which is the same as
libiconv-2.dll more or less), but PostGIS the way it is compiled needs it to
be called libiconv-2.dll
Mark correct me if anything I send is wrong.
Hope that helps,
Regina
_____
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Waddell,
Dave FOR:EX
Sent: Wednesday, August 05, 2009 6:57 PM
To: postgis-devel at postgis.refractions.net
Subject: [postgis-devel] PostGIS 1.4 and PostgreSQL 8.4
I'm getting ready to build a custom install of PostgreSQL 8.4 and PostGIS
1.4 for a locked down gov't 32bit vista installation.
(Normal installs will not work due to access restrictions).
PostgreSQL binaries (postgresql-8.4.0-1-windows-binaries.zip) were
downloaded from <http://www.enterprisedb.com/products/pgbindownload.do>
PostGIS binaries (postgis-pg84-binaries-1.4.0.zip) were downloaded from
<http://postgis.refractions.net/download/windows/>
In looking at the /bin for the PostgreSQL 8.4 install and comparing to the
PostGIS 1.4 binaries,
both /bin directories contain libiconv-2.dll , but they are a different
size.
PostgreSQL PostGIS
947KB 905KB
There have been installation issues posted before about libiconv.dll.
Which is the correct dll to use??
Thanks in advance
Dave Waddell
Forest Analysis & Inventory Branch
Ministry of Forests & Range
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090806/3752b7ed/attachment.html>
