[postgis-devel] Typmod Goodness
Paragon Corporation
lr at pcorp.us
Fri Aug 7 13:01:08 PDT 2009
Oh no another -- but lets do it like the way Oracle does it :)
Actually I like the idea of having 2 views, because if I have a database
with a 1000 spatial tables in it, I normally don't care to wait around to
see everyone else's stuff.
I believe pg_tables and information_schema.tables do have a filter, but I
think its based on priviledge (or am I thinking about pg_settings). Steve --
you happen to know anything about that one way or the other?
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
Neufeld
Sent: Friday, August 07, 2009 3:52 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Typmod Goodness
I'm not partial either way, but perhaps it might be an idea to follow
Oracle's example:
http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_objrelsch
ema.htm#i1001937
Have two views. One to list the geography_columns in the user's search_path,
and one to list all geography_columns which the user has select access to.
-- Kevin
Stephen Frost wrote:
> * Paragon Corporation (lr at pcorp.us) wrote:
>> I disagree with the pg_table_is_visible = true addition (if it
>> ensures only tables in your search path).
> So do I. I equate 'geometry_columns' and 'geography_columns' to
> 'pg_class', 'pg_tables', or 'information_schema.tables', none of which
> have any such filter based on current search_path. That's something
> implemented in the client, where necessary and appropriate.
> Thanks,
> Stephen
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
