[postgis-devel] Typmod Goodness
Stephen Frost
sfrost at snowman.net
Fri Aug 7 13:07:57 PDT 2009
* Paragon Corporation (lr at pcorp.us) wrote:
> Actually I like the idea of having 2 views, because if I have a database
> with a 1000 spatial tables in it, I normally don't care to wait around to
> see everyone else's stuff.
I'd be alright with filtering things you can't access.
> I believe pg_tables and information_schema.tables do have a filter, but I
> think its based on priviledge (or am I thinking about pg_settings). Steve --
> you happen to know anything about that one way or the other?
pg_catalog tables typically don't filter. pg_tables isn't filtered.
The information_schema does typically filter, and
information_schema.tables does have a filter on permissions:
pg_has_role(c.relowner, 'USAGE'::text) OR
has_table_privilege(c.oid, 'SELECT'::text) OR
has_table_privilege(c.oid, 'INSERT'::text) OR
has_table_privilege(c.oid, 'UPDATE'::text) OR
has_table_privilege(c.oid, 'DELETE'::text) OR
has_table_privilege(c.oid, 'REFERENCES'::text) OR
has_table_privilege(c.oid, 'TRIGGER'::text)
Thanks,
Stephen
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
> Neufeld
> Sent: Friday, August 07, 2009 3:52 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Typmod Goodness
> I'm not partial either way, but perhaps it might be an idea to follow
> Oracle's example:
> http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_objrelsch
> ema.htm#i1001937
> Have two views. One to list the geography_columns in the user's search_path,
> and one to list all geography_columns which the user has select access to.
> -- Kevin
> >> I disagree with the pg_table_is_visible = true addition (if it
> >> ensures only tables in your search path).
> > So do I. I equate 'geometry_columns' and 'geography_columns' to
> > 'pg_class', 'pg_tables', or 'information_schema.tables', none of which
> > have any such filter based on current search_path. That's something
> > implemented in the client, where necessary and appropriate.
> > Thanks,
> > Stephen
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090807/8f57f3da/attachment.sig>
