[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
trac at osgeo.org
Fri Dec 11 11:19:47 PST 2009
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Paul,
>Good instructions. I ended up just reducing the priv on my account and
running in --> single. My trace is no more informative than yours.
Your trace is not any more informative than mine? or Olivier's
The way I do it -- I compiled my PostgreSQL under MingW with debug mode as
Mark said (I updated Mark's instructions in a Tip section for that).
Then what I do after that of course after init Dbing my MingW PostgreSQL
install.
I have my MingW install running under Port 8434 and then I manually start
it from windows dos shell with this command
"C:\projects\pg\pg84\bin\pg_ctl" start -D "C:\projects\pg\pg84\data" -U
postgres
Then I connect to it using pgAdmin III, run my query -- do contd. bt dance
-- as per Mark's instructions .
But I'm running on Windows XP. Haven't tried under Vista or my Windows 7
yet - don't have those boxes set up.
I have yet to compile PostgreSQL under VS -- have it almost compiling --
still have to drag in some dependencies. Then I should be able to do a
more detailed debug under that too and maybe fix my damn R so PL/R will
work under my regular windows installs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:40>
