[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
PostGIS trac at osgeo.org
Fri Dec 11 11:40:18 PST 2009
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 You can tell two ways.  You can check with depends.exe or look at the size
 of the postgis-1.5.dll.  If its static it will be much fatter than your
 original since it will have the libxml embedded in it.
 The libxml added about another 1 mb to the .dll file.  though we can
 probably reduce that by disabling stuff we don't need.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:42>
