[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
trac at osgeo.org
Mon Dec 21 06:11:33 PST 2009
Reporter: pramsey | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by mcayland):
Sadly creating subdirectories for module content is something which PGXS
in its current incarnation cannot do particularly well :(
After wrestling for several hours with various bits of Makefile, I
eventually realised that I was trying to make things more complicated than
they should be. Looking at the PGXS source file, the installation code
uses the following to install into datadir:
$(INSTALL_DATA) $$file '$(DESTDIR)$(datadir)/contrib'
So I've implemented the attached hack that alters datadir from its
original value so that "make install" will now place things under
~/share/postgresql/contrib/postgis-X.Y/contrib. Alas it should be obvious
from the above that I can't remove the trailing contrib from the PATH
without altering PGXS :(
Can people have a play with this and let me know if they think it's an
acceptable solution? Ultimately I'd like to bump something better up to
the PostgreSQL guys, however this should go some way to solving the
immediate problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/311#comment:3>
