[postgis-devel] trying PostGIS online, here it omes
Nicklas =?utf-8?Q?Av=E9n?= nicklas.aven at jordogskog.no
Sun Dec 20 02:09:28 PST 2009
You are right  I am sorry. I thought it was just the "c" in the subject that was missing :-)Here it should come /Nicklas
2009-12-20 Frode Wiseth Jørgensen wrote:
>Hi Nicklas
>Is the attachment missing (zipfile) ?
>Cheers
>Frode
>Nicklas Avén wrote:
>> Ok sorry for some days delay. I just had to find some time to write some
>> comments in the code. This is what I've got so far. I have installed using
>> the windows installe from OSGeo4Wand just checked, ApacheMapserver
>> CGIFastCGIProj There is some notes in the readme.txt about nessesary
>> configuration. the zipfile also includes a database dump named
>> pgonline.backup Regards Nicklas
>> 2009-12-16 George Silva wrote:
>> This is a great idea and can bring a lot of people into using the
>> software.>
>> There is a major difficulty in starting with PostGIS because you cannot
>> see your data. Many users and power-users wishes to convert, but they lack
>> that "graphic" ArcCatalog window.>
>> For me at least was one of the barriers i found when i first started.
>> Being able to show future users the funcionalities of PostGIS without
>> installing and giving them the freedom to experiment is a vry good idea.
>> Congratulations for that.>
>> If you need any help, I'm up for it.>
>> George
>> On Wed, Dec 16, 2009 at 12:03 PM, Marc Jansen
>> wrote:
>>>Hi Nicklas,
>>>find my answers inline: >
>>>Nicklas Avén wrote:
>>>Hallo Mark
>>> Great :-)
>>> Absolutely, we should try to get something useful out of this together.
>>>Maybe we simply chat when the book is published? What do you think? >
>>> What is producing your maps? Mapserver, geoserver?
>>>I have a background world-WMS served by I-don't-know... it's external, I
>simply use the service. The spatial data from a query is being rendered by
>the browser as vectorgraphics (OpenLayers allows you to display e.g.
>WKT-Strings as vector data, SVG, VML etc.). >
>>> I have one longterm-thought about this (seen from my situation as a
>>> novice hacker trying my best :-)) , give me a few lines to explain:
>>> I think PostGIS gets too samll attention at least in this part of the
>>> world. Here I have focused on two reasons I think is obvious.
>>>1) as I wrote in last post, people doesn't at once see the possibility
>to use spatial sql-queris for analyses, they just use the spatial database
>for storing. An online testarea to send everybody little curious could maybe
>help some of that.
>>>Yes, maybe. >
>>>2) I think it is a weakness that almost no webhotels can offer a PostGIS
>functionality (together with mapserver or Geoserver) and I think one problem
>is to be able to manage your spatial data on a webhotel. Other data you can
>manage with phppgAdmin in postgresql. Of cource you can manage spatial data
>to like that but you will easily get a feeling that you don't have control
>if you can't easily see your data. So I think maybe the webhotels would be
>more intrested if there were a web user interface to the spatial data.
>>>webhotels are webhosters, right ? :-) I am not an expert in that field,
>bnut would guess that only few of them offer a PostgreSQL-database, and even
>fewer one with PostGIS preinstalled... at least within the minimal package
>that includes a database.
>>>As for the simple preview of stored spatial data from with phppgadmin, I
>am pretty sure I remember a plugin that did that. Not sure what it was
>called though, sorry >
>>> So my plan is to get this tutorial site (not nessesary from my initial
>>> approach) running, hoping for people to contribute in the development of
>>> the site. That will have a positive effect on PostGIS during this
>>> development process and maybe it will give ideas and encourage someone to
>>> implement it in for example phppgAdmin.
>>> It's not illegal to be naive :-)
>>>I don't think you are naive. Publishing your ideas (or solutions to
>problems you happen to stumble upon) is the core of OSS, isn't it? Who knows
>if someone will jump on the train? No one will join you if you don't
>publish... so go on, release early and often!
>>>Regards,
>>>Marc
>> /Nicklas
>>>2009-12-16 Marc Jansen wrote:
>>>Hi Nicklas, Hi list,
>>>>I love the idea of trying SQLs in a browser and instantly get a spatial
>>>>result! Actually I have built an OpenLayers [1] client for an upcoming
>>> >book of mine [2] that does this. Furthermore I wanted to transform that
>>>>special bit of code (the interactive terminal and the OpenLayers client)
>>>>into an OpenSource application. Actally I recently submitted a talk to
>>> >the german conference FOSSGIS [3] -- organized by the local german
>>>>chapter FOSSGIS [4] of the OSGEO -- that wants to discuss the project
>>>>and further possible development. The talk is not yet accepted.
>>>>I took a slightly different appproach (Mainly because the initiual
>>>>application was being developed for the book):
>>>> * One opens the address of the application in the browser
>>>> * You see a world map (an external WMS) in a minimal OpenLayers-Client
>>> > * below the Map there is a terminal where you can enter more or less
>>>> any SQL
>>>> * Upon submission of the form data is sent via AJAX to aserver side
>>>> script
>>>> * that script does some checking and finally queries the database
>>> > and gioves the result back to the client
>>>> * if the result of the query is a geometry, it gets displayed on
>>>> the map as a vector geometry instantly
>>>> * if the result is a meta-infomation (eg ST_Area, etc.) That Info
>>> > is displayed in the client.
>>>> * There are some restrictions currently (allowed projections, number
>>>> of returned records and the like)
>>>>I have working code for all of the above, but have to wait to publish
>>> >the details until the book is finally there (that would be February
>>>>2010, hopefully). All the code in the book will be released under the
>>>>BSD license.
>>>>I see a big potential for an application like that (or the one you
>>> >describe), so please contact me on- or offlist if you see any chance on
>>>>working together on something like this.
>>>>Best regards,
>>>>Marc
>>>>PS: Please excuse that I start a new thread because I couldn't reply
>>> >directly to the original email.
>>>>[1] openlayers.org
>>>>[2] german only:
>>>>www.amazon.de/OpenLayers-Webentwicklung-dynamischen-Karten-Geodaten/dp/3937514929/ref=sr_1_1?ie=UTF8&s=books&qid=1260946463&sr=8-1
>>> >[3] www.fossgis.de/konferenz/wiki/Main_Page
>>>>[4] www.fossgis.de/
>>>>Original email from Nicklas:
>>>>Hallo
>>>>I have had an idea about a site where people can try and test postgis
>>>>online.
>>>>Working with spatial data in db-environment I think a lot of people
>>> >seems like abstract and maybe suspect and
>>>>their picture of analyse spatial data is often tightly connected to some
>>>>Arc-products.
>>>>So, now I have come up with something as a start.
>>> >The basic idea is that a sql-string generates a view or a table that
>>>>mapserver produces a transparent gif-image from.
>>>>The idea of working with transparent images is that you can produce many
>>>>(three in the application of today) images that will be put on top of
>>> >each other. The first defines the extent and the others will be showed
>>>>on top.
>>>> From this concept I continued and found a way of easily producing
>>>>tutorials.
>>>>The idea is that a tutorial (defined by some objects in a html-file)
>>> >controls 4 objects in the window (see attached picture):
>>>>* the text in a describing text -holder to the right in the screen
>>>>* the text in the sql-string text area, so the user can just click a
>>>>button to see the result, modify it and try again
>>> >* Background map, One of the maps in the dataabse, shown "as is" in full
>>>>extent or in extent defined by Map1
>>>>* An image, it is possible to, instead of the map give the url to an
>>>>image. Might b convinient for showing something in the tutorial
>>>> From this tools it should be easy, bith to present all the PostGIS
>>>>functions and explain new things like Geography-type or wkt-raster.
>>>>I think it could give many sql-gurus an aha-experiense to see the
>>> >possibilities of analysing spatial data with sql.
>>>>I have bought postgisonline.org for the purpose. (Thought it was best
>>>>buying it before discussing it in public :-)
>>> >There is also other suggestions but I don't know if that was an option
>>>>for sure or just maybe . I have no opinion in that question.
>>>>Does it sound interesting?
>>>>I would like it all to be open source. Do I haev to but some special
>>> >text in the files. Do I/we risk anything if I just dump it all to this
>>>>list?
>>>>about the attached pictures:
>>>>* the artistic example is Reginas example in documentation to
>>>>st_longestline, buffered with 1, 2 respective 5 units on top of eachother
>>> >* picture.jpeg is the page 2 of a tutorial shoving what it looks like.
>>>>Not very fancy, but I'm little alergic to heavy fanciness on the web.
>>>> But should maybe be little more good looking with colors and so on.
>>>>Regards
>>>>Nicklas
>>>>_______________________________________________
>>>>postgis-devel mailing list
>>>>postgis-devel at postgis.refractions.net
>>> >postgis.refractions.net/mailman/listinfo/postgis-devel
>>> Dipl.-Geogr. Marc Jansen
>>> - Anwendungsentwickler -
>>> terrestris GmbH & Co. KG
>>> Irmintrudisstraße 17
>>> 53111 Bonn
>>> Tel: ++49 (0)228 / 96 28 99 -53
>>> Fax: ++49 (0)228 / 96 28 99 -57
>>> Email: jansen at terrestris.de
>>> Web: www.terrestris.de
>>> Amtsgericht Bonn, HRA 6835
>>> Komplementärin: terrestris Verwaltungsgesellschaft mbH
>>> vertreten durch: Hinrich Paulsen, Till Adams >
>>>George R. C. Silva
>>>Desenvolvimento em GIS
>>>www.sextantegeo2.blogspot.com
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>View this message in context: http://old.nabble.com/trying-PostGIS-online%2C-here-it-omes-tp26855944p26861936.html
>Sent from the PostGIS - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091220/12393f36/attachment.html>
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091220/12393f36/attachment.bin>
