[postgis-devel] Several problems with shapeloader GUI
Nicklas Avén
nicklas.aven at jordogskog.no
Sun Dec 27 17:15:42 PST 2009
Ok, Now I have done some progress. I think your fix worked Mark But I ended up with an corrupt postgis dll (some error 126, I will try it a little more tomorrow, postgis has become more difficult to compile lately :-) ) so I had to use the one from the experimental build. So what I did was just replacing the shp2pgsql-gui.exe from the experimental build with the one I compiled now. Then it worked :-) But still some strange behavior:1) As you said Mark, still that window exploding out in the right when a long sql-string is showed (like when I tried the corrupt postgis dll)2) The filter for only howing shapefiles in file-dialog doesn't work when dialog is opened second time3) make install didn't move shp2pgsql-gui.exe to installation folder so I had to fetch it from source tree And one noteI had to add --with-xml2config=/c/.....when configuring. Now I leave for bed Nicklas
2009-12-28 Mark Cave-Ayland wrote:
Nicklas Avén wrote:
>> Hallo Mark
>> My results was from the experimental builds. I have never succeded to
>> compile with GTK and libxml2. I have tried now but I get an error like this:
>> lwgeom_functions_basic.c: In function `postgis_libxml_version':
>> lwgeom_functions_basic.c:204: error: `POSTGIS_LIBXML2_VERSION'
>> undeclared (first use in this function)
>> lwgeom_functions_basic.c:204: error: (Each undeclared identifier is
>> reported only once
>> lwgeom_functions_basic.c:204: error: for each function it appears in.)
>> make[1]: *** [lwgeom_functions_basic.o] Error 1
>> make[1]: Leaving directory `/c/utv/src/pg15/postgis'
>> make: *** [postgis] Error 2
>> I don't really get where it should get the POSTGIS_LIBXML2_VERSION from.
>> Doxygen says it should get it from sqldefines.h but in changeset 4885
>> this is added in configure.ac
>> POSTGIS_LIBXML2_VERSION=`$XML2CONFIG --version
>> What am I missing?
>> Nicklas
>Try re-running autogen.sh, then configure.
>HTH,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091228/8484a585/attachment.html>
