[postgis-devel] Several problems with shapeloader GUI
Nicklas Avén nicklas.aven at jordogskog.no
Mon Dec 28 03:50:18 PST 2009
Great Thanks Regina. Your new experimental gui seems to work fine. It laoded as it should and when there already eas a gid-column it just made a new one with name __gid. What still is left is that the shapefile-filter in file dialog is unstableand a new fenomena is that under options the "policy for records with empty (null) shaped) defaults to 7751720.Is that a pointer or.... I like this GUI. Before I have used SPIT with QGIS, but I really see the advantage of having it in pgAdmin with the connection properties pointing to the marked db. Very nice :-) Nicklas
2009-12-28 Nicklas Avén wrote:
>Ok, >Now I have done some progress.> >I think your fix worked Mark> >But I ended up with an corrupt postgis dll (some error 126, I will try it a little more tomorrow, postgis has become more difficult to compile lately :-) ) so I had to use the one from the experimental build. So what I did was just  replacing the shp2pgsql-gui.exe from the experimental build with the one I compiled now.> >Then it worked :-)> >But still some strange behavior:>1) As you said Mark, still that window exploding out in the right when a long sql-string is showed (like when I tried the corrupt postgis dll)>2) The filter for only howing shapefiles in file-dialog doesn't work when dialog is opened second time>3) make install didn't move shp2pgsql-gui.exe to installation folder so I had to fetch it from source tree> >And one note>I had to add >--with-xml2config=/c/.....>when configuring.> >Now I leave for bed> >Nicklas
> 2009-12-28 Mark Cave-Ayland wrote:
> Nicklas Avén wrote:
> >> Hallo Mark
> >> My results was from the experimental builds. I have never succeded to
> >> compile with GTK and libxml2. I have tried now but I get an error like this:
> >> lwgeom_functions_basic.c: In function `postgis_libxml_version':
> >> lwgeom_functions_basic.c:204: error: `POSTGIS_LIBXML2_VERSION'
> >> undeclared (first use in this function)
> >> lwgeom_functions_basic.c:204: error: (Each undeclared identifier is
> >> reported only once
> >> lwgeom_functions_basic.c:204: error: for each function it appears in.)
> >> make[1]: *** [lwgeom_functions_basic.o] Error 1
> >> make[1]: Leaving directory `/c/utv/src/pg15/postgis'
> >> make: *** [postgis] Error 2
> >> I don't really get where it should get the POSTGIS_LIBXML2_VERSION from.
> >> Doxygen says it should get it from sqldefines.h but in changeset 4885
> >> this is added in configure.ac
> >> POSTGIS_LIBXML2_VERSION=`$XML2CONFIG --version
> >> What am I missing?
> >> Nicklas
> >Try re-running autogen.sh, then configure.
> >HTH,
> >Mark.
> >Mark Cave-Ayland - Senior Technical Architect
> >PostgreSQL - PostGIS
> >Sirius Corporation plc - control through freedom
> >www.siriusit.co.uk
> >t: +44 870 608 0063
> >Sirius Labs: http://www.siriusit.co.uk/labs
> >_______________________________________________
> >postgis-devel mailing list
> >postgis-devel at postgis.refractions.net
> >postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091228/8aacec9a/attachment.html>
