[postgis-devel] Issue 110 in postgis: shp2pgsql new option to not batch commit
codesite-noreply at google.com codesite-noreply at google.com
Sun Feb 1 09:50:53 PST 2009
Status: New
Owner: robe.... at cityofboston.gov
Labels: Type-Enhancement Milestone-1.4
New issue 110 by robe.... at cityofboston.gov: shp2pgsql new option to not
batch commit
http://code.google.com/p/postgis/issues/detail?id=110
What steps will reproduce the problem?
1. If you have some geometries that fail insert such as polygons without
closed rings, it kills the current batch and gives a more or less
meaningless message
2. This has happened to me a lot and a lot of users we train.  A lot of the
time the data should just rightfully not be added.
3. Write now to overcome this I generate a .sql file and use sed to remove
the begin commits which means I can't use the normal | to directly load
I think the simplest option is to allow users with a flag to have the
option to not have begin commits so that everything is in its own
transaction.  That way at least a whole batch of good records aren't lost
because of one bad apple.
I know we have talked about other options such as allowing these beasts
into the database or nulling the geometry if invalid etc -- though those
options are trickier to implement and may not handle all cases.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
