[postgis-devel] Issue 110 in postgis: shp2pgsql new option to not batch commit
codesite-noreply at google.com codesite-noreply at google.com
Wed Feb 4 03:18:50 PST 2009
Comment #1 on issue 110 by mark.cav... at siriusit.co.uk: shp2pgsql new option
to not batch commit
http://code.google.com/p/postgis/issues/detail?id=110
Two things here:
i) Inserting transactions throughout a large dataset is, IMHO, wrong. You
either want
the whole set of data inserted atomically, or you handle the consequences
yourself.
So I would suggest removing all of the code related to batching in
LoadData() and
just have one single BEGIN...COMMIT block. At least then if the insert
fails, you can
manually remove the BEGIN/COMMIT yourself and live with what gets inserted.
ii) The 1.4 version of loader currently throws an error if an invalid
geometry is
inserted; it would be fairly easy to modify this so that the erroneus
geometry were
simply omitted.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
