[postgis-devel] FWD: BUG #4638: Bug with Geometry in Array
Kevin Neufeld
kneufeld at refractions.net
Tue Feb 3 09:36:06 PST 2009
Yes, this does appear to be a bug with JDBC and the PGgeometry datatype (at least with v8.3-604.jdbc3.jar, this feature
is not implemented yet in version 8.2).
If I run this code segment:
ResultSet rset = stmt.executeQuery("SELECT ARRAY(SELECT column1 FROM "
+ "(VALUES ('POINT(0 0)'::text), ('POINT(0 0)'::text)) AS foo)");
while (rset.next()) {
Array a = rset.getArray(1);
System.out.println(a.getClass() + " # " + a.toString());
ResultSet rs = a.getResultSet();
while (rs.next()) {
System.out.print(rs.getObject(1).getClass().toString() + " # " + rs.getObject(1)
+ "\t");
System.out.println(rs.getObject(2).getClass().toString() + " # " + rs.getObject(2));
I get can iterate through both array fields. This yields:
class org.postgresql.jdbc3.Jdbc3Array # {"POINT(0 0)","POINT(0 0)"}
class java.lang.Integer # 1 class java.lang.String # POINT(0 0)
class java.lang.Integer # 2 class java.lang.String # POINT(0 0)
If I cast them to type "geometry" I only get one array field:
{010100000000000000000000000000000000000000:010100000000000000000000000000000000000000}
class java.lang.Integer # 1 class org.postgis.PGgeometry # POINT(0 0)
BOX2D and BOX3D do seem to work though:
class org.postgresql.jdbc3.Jdbc3Array # {"BOX3D(0 0 0,1 1 0)","BOX3D(0 0 0,1 1 0)"}
class java.lang.Integer # 1 class org.postgis.PGbox3d # BOX3D(0 0 0,1 1 0)
class java.lang.Integer # 2 class org.postgis.PGbox3d # BOX3D(0 0 0,1 1 0)
This seems limited to the PGgeometry datatype.
Cheers,
Kevin
Tom Lane wrote:
> Can anyone here reproduce the behavior complained of below?
> (I haven't got postgis installed ATM, so not convenient to try it
> myself)
> regards, tom lane
> ------- Forwarded Message
> Date: Tue, 3 Feb 2009 12:49:22 GMT
> From: "Bjoern Weitzig" <weitzig at supportgis.de>
> To: pgsql-bugs at postgresql.org
> Subject: [BUGS] BUG #4638: Bug with Geometry in Array
> The following bug has been logged online:
> Bug reference: 4638
> Logged by: Bjoern Weitzig
> Email address: weitzig at supportgis.de
> PostgreSQL version: 8.3.5
> Operating system: Windows
> Description: Bug with Geometry in Array
> Details:
> System: PostgreSQL 8.3.5, compiled by Visual C++ build 1400
> (Windows-Installer), PostGIS 1.3.5, GEOS 3.0.3-CAPI-1.4.2 on Windows
> I use arrays like "select array(select n from a)". This works well except of
> the case with geometry as datatype.
> In case of geometry, the JDBC ResultSet.getArray(1).getResultSet() only
> lists the first element.
> Testcase:
> create table a(n VARCHAR);
> SELECT AddGeometryColumn( 'a', 'feature', -1, 'GEOMETRY', 3 );
> INSERT INTO a(n, feature) VALUES (1,GeomFromText('Point(1 1 0)',-1));
> INSERT INTO a(n, feature) VALUES (2,GeomFromText('Point(2 2 0)',-1));
> select array(select n from a);
> => "{1,2}" (ok)
> select array(select feature from a);
> "{0101000080000000000000F03F000000000000F03F0000000000000000:010100008000000
> 0000000004000000000000000400000000000000000}"
> I wonder why there is a ":" instead of an ",".
> JDBC:
> ResultSet rset = stmt.executeQuery("select array(select feature from
> a)");
> if (rset.next()) {
> Array array = rset.getArray(1);
> ResultSet rs2 = array.getResultSet();
> int n=0;
> while (rs2.next()) {
> Object o = rs2.getObject(2);
> n++;
> System.out.println(n+": "+o);
> rs2.close();
> This lists only the first point "1: POINT(1 1 0)", instead of expected "1:
> POINT(1 1 0) \n 2: POINT(2 2 0)"
