[postgis-devel] Issue 106 in postgis: pgsql2shp memory leak on WIndows
codesite-noreply at google.com codesite-noreply at google.com
Tue Feb 3 15:52:33 PST 2009
Comment #3 on issue 106 by krellor: pgsql2shp memory leak on WIndows
http://code.google.com/p/postgis/issues/detail?id=106
Ok, I tested it and it seems to work.  Also, the prj file worked fine for
me.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
