[postgis-devel] Issue 112 in postgis: ST_CurveToLine sometimes crashes server
codesite-noreply at google.com codesite-noreply at google.com
Tue Feb 3 16:05:59 PST 2009
Comment #2 on issue 112 by mrk.leslie: ST_CurveToLine sometimes crashes
server
http://code.google.com/p/postgis/issues/detail?id=112
Distilled the test case down to:
SELECT ST_CurveToLine('GEOMETRYCOLLECTION(POINT(-10 50))'::geometry);
Effects both 1.3 branch and trunk.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
