[postgis-devel] Issue 112 in postgis: ST_CurveToLine sometimes crashes server
codesite-noreply at google.com
Wed Feb 4 08:04:24 PST 2009
Comment #3 on issue 112 by mark.cav... at siriusit.co.uk: ST_CurveToLine
http://code.google.com/p/postgis/issues/detail?id=112
Arrgh! I've worked out what's happening here: basically
pglwgeom_serialize() alters
its input geometry which should be a total no-no. The fix should be to
remove this
horrible piece of code from pglwgeom_serialize:
#if POSTGIS_AUTOCACHE_BBOX
if ( ! in->bbox && is_worth_caching_lwgeom_bbox(in) )
lwgeom_addBBOX(in);
#endif
and then go around the rest of the codebase fixing up any callers that
require it.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
