[postgis-devel] Issue 95 in postgis: PostGIS 1.4 documentation update
codesite-noreply at google.com codesite-noreply at google.com
Wed Feb 4 03:26:52 PST 2009
Comment #7 on issue 95 by mark.cav... at siriusit.co.uk: PostGIS 1.4
http://code.google.com/p/postgis/issues/detail?id=95
Okay, so I see that the operators have now gone into the SVN documentation.
The
interesting part is that most of the operators are labelled as "This
operand will NOT
make use of any indexes that may be available on the geometries" but this
is totally
untrue; please see lwgeom_gist.c:lwgeom_rtree_internal_consistent and
you'll see that
all operators support index usage!
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
