[postgis-devel] Issue 95 in postgis: PostGIS 1.4 documentation update
codesite-noreply at google.com
Wed Feb 4 09:39:07 PST 2009
Comment #8 on issue 95 by ke... at refractions.net: PostGIS 1.4 documentation
update
http://code.google.com/p/postgis/issues/detail?id=95
As I ported all the operators over, I tested each one with against a
multi-gigabyte
linear table. Only a few ever invoked the GIST index. It occurred to me
just now
that I might have done that against a slightly older PostGIS version. Were
they
always supposed to invoke the index, or was this a recent change? I'll
have to
retest against SVN head...
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
