[postgis-devel] Issue 76 in postgis: ST_DumpPoints - I think we said we would add to TODO
codesite-noreply at google.com codesite-noreply at google.com
Thu Feb 5 10:36:41 PST 2009
Comment #1 on issue 76 by ke... at refractions.net: ST_DumpPoints - I think we
http://code.google.com/p/postgis/issues/detail?id=76
Wow.  An actual use case for the "path" part of ST_DumpRings.
http://postgis.refractions.net/pipermail/postgis-users/2009-February/022674.html
I guess it would good to have a similar datatype for ST_DumpPoints.
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
