[postgis-devel] Making postgis_comments.sql
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Feb 23 00:12:03 PST 2009
Obe, Regina wrote:
> I tried to change the Makefile.in in docs/ to autogenerate the
> postgis_comments.sql, but don't seem to be having much luck.
> Can some make wizard tell me what I am doing wrong.
> I created as section postgis_comments.sql to define the compile
> and in the all: call that.
It works for me, although don't forget that you need to re-run configure
so that the new Makefile gets generated from configure.in.
> Also wondering where this file should sit. I guess ideally it should
> sit at the root with spatial_ref_sys.sql as it does in the 1.3.
That should be fairly easy to do; just change postgis_comments.sql to
../postgis_comments.sql.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
