[postgis-devel] Making postgis_comments.sql
Kevin Neufeld kneufeld at refractions.net
Mon Feb 23 09:05:58 PST 2009
I purposely setup Hudson so it *doesn't* use the all target.  The 'all' target is set to build the single html file
'html/postgis.html'.  I didn't think we wanted that ... rather, I'm specifically calling 'make chunked-html' (builds the
multiple html files we currently have for the docs website) and then 'make pdf'.
I just added your target of 'make ../postgis_comments.sql' to the Hudson build list.  You should now find your sql file
the svn tarball.
Do you still want it to make 'all'?
Cheers,
-- Kevin
Mark Cave-Ayland wrote:
> Obe, Regina wrote:
>> Then how come when I download the svn build from the site, I don't see
>> it in there?  Is there something wrong with the hudson build that its
>> not doing a re-run of configure maybe?
> I suspect you'll find that the Hudson build runs the pdf target directly
> rather than the all target - but you'll need to check the logs.
>> Okay will give this a try.  I assume this has to be the name of the
>> action as well or does it just have to be the actual action like.  so I
>> would change to
>> all: html/postgis.html    ../postgis_comments.sql
>> ../postgis_comments.sql: ./xsl/postgis_comments.sql.xsl
>> reference_new.xml
>>     $(XSLTPROC) ./xsl/postgis_comments.sql.xsl reference_new.xml >
> Yup, that's it - you'll need to change both.
> ATB,
> Mark.
