[postgis-devel] Making postgis_comments.sql
Obe, Regina
robe.dnd at cityofboston.gov
Mon Feb 23 09:24:54 PST 2009
Kevin,
Thanks - that will do. I just cared about it being in the downloadable file and don't care too much about how it gets there.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Kevin Neufeld
Sent: Mon 2/23/2009 12:05 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Making postgis_comments.sql
I purposely setup Hudson so it *doesn't* use the all target. The 'all' target is set to build the single html file
'html/postgis.html'. I didn't think we wanted that ... rather, I'm specifically calling 'make chunked-html' (builds the
multiple html files we currently have for the docs website) and then 'make pdf'.
I just added your target of 'make ../postgis_comments.sql' to the Hudson build list. You should now find your sql file
the svn tarball.
Do you still want it to make 'all'?
Cheers,
-- Kevin
Mark Cave-Ayland wrote:
> Obe, Regina wrote:
>> Then how come when I download the svn build from the site, I don't see
>> it in there? Is there something wrong with the hudson build that its
>> not doing a re-run of configure maybe?
> I suspect you'll find that the Hudson build runs the pdf target directly
> rather than the all target - but you'll need to check the logs.
>> Okay will give this a try. I assume this has to be the name of the
>> action as well or does it just have to be the actual action like. so I
>> would change to
>> all: html/postgis.html ../postgis_comments.sql
>> ../postgis_comments.sql: ./xsl/postgis_comments.sql.xsl
>> reference_new.xml
>> $(XSLTPROC) ./xsl/postgis_comments.sql.xsl reference_new.xml >
> Yup, that's it - you'll need to change both.
> ATB,
> Mark.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090223/4fb8eb2d/attachment.html>
