[postgis-devel] Issue 90 in postgis: AddGeometryColumn inappropriately defaults to current_schema() if given nonexistent schema
codesite-noreply at google.com
Wed Jan 7 09:32:04 PST 2009
Updates:
Status: Fixed
Labels: -Type-Enhancement -Milestone-1.4 Type-Defect Milestone-1.3.X
Comment #6 on issue 90 by ke... at refractions.net: AddGeometryColumn
http://code.google.com/p/postgis/issues/detail?id=90
Hi Reid,
I appreciate your feedback. You're right that this subtle case is not well
documented (something I just fixed in the trunk docs). Fair enough, it's a
subtle
change and could be classified as a bug since an error is being thrown
anyway. I
just committed the patch to 1.3
Cheers,
Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
