[postgis-devel] Issue 90 in postgis: AddGeometryColumn inappropriately defaults to current_schema() if given nonexistent schema
codesite-noreply at google.com
Wed Jan 7 08:55:49 PST 2009
Comment #5 on issue 90 by reid at reidster.net: AddGeometryColumn
http://code.google.com/p/postgis/issues/detail?id=90
Kevin,
Very glad to hear it'll be fixed in 1.4.
> Applying the patch to 1.3 would change the behaviour of the method, which
is not
> appropriate for a micro release.
Without knowing the PostGIS policy on this (it's certainly not that
changing the
behavior of methods is out, since that excludes all bugfixes), I'd like to
push back
a bit: the current behavior is not documented, so I don't see how it
changes the
advertised interface, and I do believe it violates the principle of least
surprise
rather severely.
It could also lead to incorrect behavior: suppose that I have two tables,
pg_temp1.foo_tmp and public.foo. If I call
AddGeometryColumn('temp', 'foo', ...) --
i.e., I got the name of the temp tablespace wrong and I forgot the _tmp
suffix --
then it would change the wrong table (foo instead of foo_tmp). This
scenario could
arise if (say) I created a temp copy of foo to do some analysis.
I agree that there are bigger fish to fry, but it's a trivial patch.
> If it ok with you, I'll close this ticket.
Not sure if you were actually waiting for me on this, but if you were, 17
hours
doesn't seem a long enough wait for someone to reply.
Thanks,
Reid
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
