[postgis-devel] Issue 90 in postgis: AddGeometryColumn inappropriately defaults to current_schema() if given nonexistent schema
codesite-noreply at google.com
Wed Jan 7 08:25:33 PST 2009
Updates:
Status: WontFix
Labels: Type-Enhancement Milestone-1.4 Priority-Low
Comment #4 on issue 90 by ke... at refractions.net: AddGeometryColumn
http://code.google.com/p/postgis/issues/detail?id=90
This issue is already addressed in trunk (the next minor release).
Applying the
patch to 1.3 would change the behaviour of the method, which is not
appropriate for a
micro release.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
