[postgis-devel] Issue 95 in postgis: PostGIS 1.4 documentation update
codesite-noreply at google.com
Fri Jan 9 02:53:11 PST 2009
Status: Accepted
Owner: mark.cav... at siriusit.co.uk
Labels: Milestone-1.4
New issue 95 by mark.cav... at siriusit.co.uk: PostGIS 1.4 documentation update
http://code.google.com/p/postgis/issues/detail?id=95
Most of the examples in the documentation still refer to the non ST_
variants of the PostGIS functions.
Given that these functions are deprecated, we really should not be trying
to encourage their use ;)
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
