[postgis-devel] Issue 95 in postgis: PostGIS 1.4 documentation update
codesite-noreply at google.com codesite-noreply at google.com
Fri Jan 9 03:51:31 PST 2009
Comment #2 on issue 95 by robe.... at cityofboston.gov: PostGIS 1.4
http://code.google.com/p/postgis/issues/detail?id=95
Its still in the old section. It is on my todo and Kevin's todo to figure
out how to
bring it into the new section.
I think Kevin was talking about new tags to describe the operators -- Here
is a
snippet from his email.  Kevin you want to do the template and I'll move
over the
operators.  Let me know if you need help with the xsl.  I think I can write
the xsl
stylesheet, but not sure how to integrate it with the doc book build.
Maybe something like this:
http://www.docbook.org/tdg/en/html/ch05.html#ex.addsect6
and extend the refentry to include an operatorsynopsis or something.
---Other relevant excerpts from our correspondence - snippet from Kevin's
email to me --
  I've been
fighting with getting the Operators moved over, but, there doesn't seem
to be proper tags for an operator type.  It looks funny using the
standard functionsynopsis tag.  I'm thinking that a custom xsl parser
could be written and and added to the docbook xsl parser.  I've done
very little to no work with stylesheets in the past.  Any idea how we
can make such a thing happen?
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
