[postgis-devel] Issue 95 in postgis: PostGIS 1.4 documentation update
Kevin Neufeld
kneufeld at refractions.net
Fri Jan 9 08:56:04 PST 2009
Oh, right.... K, I'll try to play with this a bit more this weekend.
-- Kevin
codesite-noreply at google.com wrote:
> Comment #2 on issue 95 by robe.... at cityofboston.gov: PostGIS 1.4
> http://code.google.com/p/postgis/issues/detail?id=95
> Its still in the old section. It is on my todo and Kevin's todo to
> figure out how to
> bring it into the new section.
> I think Kevin was talking about new tags to describe the operators --
> Here is a
> snippet from his email. Kevin you want to do the template and I'll move
> over the
> operators. Let me know if you need help with the xsl. I think I can
> write the xsl
> stylesheet, but not sure how to integrate it with the doc book build.
> Maybe something like this:
> http://www.docbook.org/tdg/en/html/ch05.html#ex.addsect6
> and extend the refentry to include an operatorsynopsis or something.
> ---Other relevant excerpts from our correspondence - snippet from
> Kevin's email to me --
> I've been
> fighting with getting the Operators moved over, but, there doesn't seem
> to be proper tags for an operator type. It looks funny using the
> standard functionsynopsis tag. I'm thinking that a custom xsl parser
> could be written and and added to the docbook xsl parser. I've done
> very little to no work with stylesheets in the past. Any idea how we
> can make such a thing happen?
> You received this message because you are listed in the owner
> or CC fields of this issue, or because you starred this issue.
> You may adjust your issue notification preferences at:
> http://code.google.com/hosting/settings
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
