[postgis-devel] About the ST_ prefix
Obe, Regina
robe.dnd at cityofboston.gov
Fri Jan 9 14:00:38 PST 2009
Yes I think OGC (the old standard is non-prefixed and the MM new is
ST_), but I've since forgotten old so except for GeometryType.
I use the term OGC interchangeable with MM (I mean OGC is really an
organization right so its a misnomer to begin with?)
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of strk
Sent: Friday, January 09, 2009 3:59 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] About the ST_ prefix
On Fri, Jan 09, 2009 at 09:14:05AM -0500, Obe, Regina wrote:
> The thinking (who's thinking was this? Maybe Paul) was that it would
be
> easier if people didn't have to
> worry about putting ST_ or not putting ST_ in front of functions.
Indeed I wouldn't worry and *never* use it, unless doing code supposed
to be portable across ISO-SQLMM standard dbs, in which case I'd only use
ST_ prefixed ones and count on them to be standard.
Beside, doesn't OGC expect non-prefixed ones ?
--strk;
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
