[postgis-devel] WKTRaster: RASTER and CHIP
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jan 16 08:08:35 PST 2009
Branches are cheap. We had the raster GSOC project in a branch, no
reason not to have that one there. Once it reaches the functionality
level of "does something people might find useful" we can debate
whether the API is stable enough to move it into mainline releases.
P.
On Fri, Jan 16, 2009 at 6:19 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> strk wrote:
>> Fair enough.
>> What about hosting it under the extras/ dir ?
>> --strk;
> The main issue I can see is that we are trying to work hard to stabilise
> PostGIS by enforcing a policy of no API changes in point releases, and I
> think committing the WKTRaster work directly into the PostGIS will break
> what we are trying to achieve.
> Since development is so new, I can see APIs changing rapidly and hence I
> think it would actually hold WKTRaster progress back by being restricted to
> the PostGIS release schedule. Otherwise you would be on the hook for bug
> fixing existing releases, and API changes would have to wait until the next
> minor release which could be a long time.
> I honestly think that WKTRaster would be better hosted as a separate project
> until it reaches some form of maturity, since then you are free from any of
> these restrictions. Maybe a separate branch in the PostGIS repo would also
> work, although it would put a lot more work on your shoulders to correct the
> merge conflicts. I have absolutely no problem with discussions related to
> the project/release announcements appearing on the project mailing lists
> either.
> What I believe will happen is that as the project progresses, it will soon
> mature to a steady state which should easily be determined by feedback on
> the -users mailing lists. This is then the right time to merge the code
> directly into the PostGIS codebase.
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
