[postgis-devel] WKTRaster: RASTER and CHIP
Obe, Regina
robe.dnd at cityofboston.gov
Fri Jan 16 11:19:43 PST 2009
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Friday, January 16, 2009 12:32 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] WKTRaster: RASTER and CHIP
Obe, Regina wrote:
> > Playing devlis advocate to Kevin's devils advocate.
> > I personally think its fine and am with Paul on this.
> > 1) WKT Raster has to live somewhere and it should live in the same
> > repository with PostGIS because that is the most likely place people
> > will expect to find it.
> This isn't necessarily the case; think pgrouting for an example of
this
> type of project.
I don't know I would if I would think it bad if pgrouting were included
in our repository. Seems a lot of people ask questions about it on this
list anyway. So I always thought the issue was philosophical more than
logistics.
>> 2) It is going to have to be back-patched at some point whether it
lives
>> in its own branch in PostGIS repository or someplace else in the
world.
>> So I consider the whole discussion about the difficulty of
back-patching
>> moot.
> I think Paul summarised in his email what I was saying but in much
fewer
> words; working in a branch is kinda okay as long as the WKTRaster
> developers don't mind constant merging from trunk/fixing things based
on
> changes to the PostGIS core. Although my feeling is for the initial
cut,
> it may be less work to host the project independently and do a first
> merge when it reaches a relatively stable point.
Yes I agree with branch I wasn't talking about integrating it in just
yet with
our core branches. I agree it should be a separate branch.
I'm just saying regardless of where it is hosted, you still have a
back-patch
issue so I don't see how it holds things up having it as part of our
repository and for me personally
would make it a little easier to compare.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
