[postgis-devel] Deprecation Warnings
Kevin Neufeld kneufeld at refractions.net
Fri Jan 23 14:37:01 PST 2009
:) Right.  The only reason I suppose to have the two scripts would be to make a really strong hint that people should
upgrade their apps (since they would have to purposely install the legacy sql script to make their new PostGIS install
backwards compatible).
Paul Ramsey wrote:
> Although, to answer myself, if we're doing that, is it so bad to just
> keep the damn things around? the point of removing them is....
> *removing* them. So they don't have to be thougth about anymore.
> P.
> On Fri, Jan 23, 2009 at 2:30 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
>> Right. Not even wrappers, just breaking the install into postgis.sql
>> and postgis_legacy.sql...
>> P
>> On Fri, Jan 23, 2009 at 2:25 PM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
>>> Hmm although it really wouldn't be deprecate -- it would be lets remove them
>>> and allow people to reinstate them if they want as Kevin suggested.
>>> Personally I don't care for warnings -- either keep it or get rid of it.
>>> Warnings sounds like a lot of wasted log space which will probably only be
>>> seen by logs and potentially mysteriously slow down applications in the
>>> process.
>>> Though I guess we must think of the children (Mapserver, GeoServer and
>>> ZigGIS and so forth which may be using the old names).  But then I suppose
>>> anyone using apps relying on deprecated names would just install the wrapper
>>> patch.
>>> -----Original Message-----
>>> From: postgis-devel-bounces at postgis.refractions.net on behalf of Obe, Regina
>>> Sent: Fri 1/23/2009 5:06 PM
>>> To: PostGIS Development Discussion
>>> Subject: RE: [postgis-devel] Deprecation Warnings
>>> +2
>>> From: postgis-devel-bounces at postgis.refractions.net on behalf of David
>>> William Bitner
>>> Sent: Fri 1/23/2009 4:51 PM
>>> Subject: Re: [postgis-devel] Deprecation Warnings
>>> +1, I like Cake.
>>> On Fri, Jan 23, 2009 at 2:59 PM, Kevin Neufeld
>>> <kneufeld at refractions.net>wrote:
>>>> What if we deprecate the functions as you suggest (and eventually remove
>>>> them), but provide a sql script that will reinstate them as wrappers to
>>>> the
>>>> ST_* methods.  That way, folks can have their cake and eat it too ...
>>>> upgrade to the latest version without breaking their apps.
>>>> -- Kevin
>>>> Paul Ramsey wrote:
>>>>> Could we use the function creation option
>>>>> SET configuration_parameter { TO value | = value | FROM CURRENT }
>>>>> to, for example, set postgis_deprecated to true?
>>>>> Then in the function, we could warn on deprecation. So the same
>>>>> backend to intersects() could be used by several function names, but
>>>>> only some would raise deprecation warnings.
>>>>> Or do we want to continue our gentle regime of letting the old names
>>>>> live in quite obscurity?
>>>>> P.
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>> David William Bitner
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended
>>> solely for the addressee. If you received this in error, please
>>> contact the sender and delete the material from any computer.
