[postgis-devel] Issue 102 in postgis: Fix name of f_table_schema in doc
codesite-noreply at google.com codesite-noreply at google.com
Fri Jan 23 12:08:59 PST 2009
Status: New
Owner: ----
New issue 102 by dudu... at yahoo.fr: Fix name of f_table_schema in doc
http://code.google.com/p/postgis/issues/detail?id=102
The DropGeometryColumn has incorrect documentation. The column name for the
schema in the geometry_columns table is f_table_schema and not
f_schema_name.
	fix_dropgeometrycolumn_doc.patch  544 bytes
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
