[postgis-devel] Issue 102 in postgis: Fix name of f_table_schema in doc
codesite-noreply at google.com
Fri Jan 23 13:07:14 PST 2009
Updates:
Status: Fixed
Labels: Type-Patch Priority-Low Milestone-1.4
Comment #1 on issue 102 by ke... at refractions.net: Fix name of
http://code.google.com/p/postgis/issues/detail?id=102
Committed. Thanx.
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
