[postgis-devel] Issue 104 in postgis: shp2pgsql is using deprecated PostgreSQL escape syntax
codesite-noreply at google.com
Sun Jan 25 07:20:56 PST 2009
Status: Accepted
Owner: robe.... at cityofboston.gov
Labels: Type-Defect Priority-Low
New issue 104 by robe.... at cityofboston.gov: shp2pgsql is using deprecated
http://code.google.com/p/postgis/issues/detail?id=104
For some datasets I get this
HINT: Use the escape string syntax for backslashes, e.g., E'\\'.
WARNING: nonstandard use of \\ in a string literal
LINE 1: ...w','St','Brighton','02135','Residential','3','R3','\\2003\\2...
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
