[postgis-devel] Postgis 1.4RC1 compile error
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Jul 3 02:01:02 PDT 2009
Stefano Bonnin wrote:
> I can't compile postgis 1.4rc1, when I try to compile it I receve an error.
> OS: FreeBSD 5.3
> Postgresql: 8.4
> GEOS: 3.1.1
> My compilation command is:
> ./configure --with-pgconfig=/usr/local/postgresql/8.4/bin/pg_config
> --with-geosconfig=/usr/local/bin/geos-config  --with-projdir=/usr/local
> gmake
> gmake install
(lots cut)
Thanks for the bug report. It looks as if __va_copy() is not necessarily
present on non-GNU systems. Can you test with the following patch?
Many thanks,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Type: text/x-diff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090703/3b935241/attachment.patch>
