[postgis-devel] Postgis 1.4RC1 compile error
stefano bonnin
stefano.bonnin at gmail.com
Fri Jul 3 02:48:43 PDT 2009
thnks for the patch .. it works!
2009/7/3 Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk>
> Stefano Bonnin wrote:
> I can't compile postgis 1.4rc1, when I try to compile it I receve an
>> error.
>> OS: FreeBSD 5.3
>> Postgresql: 8.4
>> GEOS: 3.1.1
>> My compilation command is:
>> ./configure --with-pgconfig=/usr/local/postgresql/8.4/bin/pg_config
>> --with-geosconfig=/usr/local/bin/geos-config --with-projdir=/usr/local
>> gmake
>> gmake install
> (lots cut)
> Thanks for the bug report. It looks as if __va_copy() is not necessarily
> present on non-GNU systems. Can you test with the following patch?
> Many thanks,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090703/071e0a81/attachment.html>
