[postgis-devel] loader/Makefile is broken in 1.4rc1
Devrim GÜNDÜZ
devrim at gunduz.org
Sat Jul 4 11:07:41 PDT 2009
On Sat, 2009-07-04 at 09:05 -0700, Kevin Neufeld wrote:
> Mark will be able to explain the change to the Makefile in more
> detail, but in short, as of 1.4 PostGIS no longer uses the --prefix
> option during configure
Why?
> so there is no DESTDIR. Rather, it installs in the
> same directory as the detected (or specified) PostgreSQL directory.
Why was it changed? Why do I have to install PostGIS under PostgreSQL
directory? I believe RPM/deb/whatever users will want to stick with FHS.
> The CPPFLAGS are not hard coded as you perceive. There is a
> Makefile.in file that configure uses to generate the actual
> Makefile.
> http://trac.osgeo.org/postgis/browser/branches/1.4/loader/Makefile.in#L22
> The /usr/local/pgsql/8.3/ path you have is the location of your
> detected (or specified) postgresql installation.
I don't have such a directory. I'm not sure how it was detected .
> I don't know why the the shape loader program is trying to install
> to /usr/bin/, that looks like a bug
> ... you should see it go to /usr/local/pgsql/8.3/bin.
See above :)
Regards,
Devrim GÜNDÜZ, RHCE
Command Prompt - http://www.CommandPrompt.com
devrim~gunduz.org, devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090704/36000f11/attachment.sig>
