[postgis-devel] st_dwithin, st_within, st_dcompletlywithin
Paragon Corporation
lr at pcorp.us
Wed Jul 8 15:22:48 PDT 2009
Oh that's what that is. Hmm and I think its already ported to PostGIS,
though would be interesting to compare the speeds and results. Since the
current one in trunk is a GEOS call and Nicklas' would be a native PostGIS.
http://trac.osgeo.org/postgis/ticket/209
Paul are you hmm planning add this to the manual -- I see you closed it? I
don't recall seeing it in the 1.5 docs or were we waiting for GEOS to be
patched first?
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Martin
Davis
Sent: Wednesday, July 08, 2009 6:14 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] st_dwithin, st_within, st_dcompletlywithin
That distance metric is known as the Hausdorff Distance. It's implemented
in JTS, and probably in GEOS as well.
nicklas.aven at jordogskog.no wrote:
> A function that gives the answer to for example:
> "How far away from France can you get in Belgia"
> To answer that we have to store compare the shortest distance to
> geometry2 from each vertex in geometry1 and finaly find wich vertex in
> geometry1 that has the highest "mindistance" to geometry2.
> Hope the idee is possible to understand. Is it of any use?
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
