[postgis-devel] st_dwithin, st_within, st_dcompletlywithin
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jul 8 15:31:22 PDT 2009
The patch included a docs patch.
On Wed, Jul 8, 2009 at 3:22 PM, Paragon Corporation<lr at pcorp.us> wrote:
> Oh that's what that is. Hmm and I think its already ported to PostGIS,
> though would be interesting to compare the speeds and results. Since the
> current one in trunk is a GEOS call and Nicklas' would be a native PostGIS.
> http://trac.osgeo.org/postgis/ticket/209
> Paul are you hmm planning add this to the manual -- I see you closed it? I
> don't recall seeing it in the 1.5 docs or were we waiting for GEOS to be
> patched first?
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Martin
> Davis
> Sent: Wednesday, July 08, 2009 6:14 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] st_dwithin, st_within, st_dcompletlywithin
> That distance metric is known as the Hausdorff Distance. It's implemented
> in JTS, and probably in GEOS as well.
> nicklas.aven at jordogskog.no wrote:
>> A function that gives the answer to for example:
>> "How far away from France can you get in Belgia"
>> To answer that we have to store compare the shortest distance to
>> geometry2 from each vertex in geometry1 and finaly find wich vertex in
>> geometry1 that has the highest "mindistance" to geometry2.
>> Hope the idee is possible to understand. Is it of any use?
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
